Nvidia Tv-out .. does this xorg.conf look right ?
DaveQB
Post by DaveQB » Sat May 06, 2006 9:04 am
From all i can read (been researching for abour 4 hours now) this config file is right, yet not working for me.
I updated my Myth box with knopmyth (wasusing an older version of knopmyth). I had it set for TV-out only as it 'worked' and i never messed with it, but did find it annouying i couldnt attached a monitor to do anything with it.
So this time i decided to try and get a clone view working
Section "ServerLayout"
        Identifier     "XFree86 Configured"
        Screen      0  "Screen0" 0 0
        InputDevice    "Keyboard0" "CoreKeyboard"
# PS/2 Mouse using /dev/input/mice in Kernel 2.6
# Serial Mouse not detected
        InputDevice    "USB Mouse" "CorePointer"
EndSection
Section "ServerFlags"
        Option "AllowMouseOpenFail"  "true"
EndSection
Section "Files"
        RgbPath      "/usr/X11R6/lib/X11/rgb"
        ModulePath   "/usr/X11R6/lib/modules"
        FontPath     "/usr/X11R6/lib/X11/fonts/misc:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/misc"
        FontPath     "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"
        FontPath     "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
        FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"
        FontPath     "/usr/X11R6/lib/X11/fonts/Speedo"
        FontPath     "/usr/X11R6/lib/X11/fonts/PEX"
# Additional fonts: Locale, Gimp, TTF...
        FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
#       FontPath     "/usr/X11R6/lib/X11/fonts/latin2/75dpi"
#       FontPath     "/usr/X11R6/lib/X11/fonts/latin2/100dpi"
# True type and type1 fonts are also handled via xftlib, see /etc/X11/XftConfig!
        FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
        FontPath     "/usr/share/fonts/ttf/western"
        FontPath     "/usr/share/fonts/ttf/decoratives"
        FontPath     "/usr/share/fonts/truetype"
        FontPath     "/usr/share/fonts/truetype/openoffice"
        FontPath     "/usr/share/fonts/truetype/ttf-bitstream-vera"
        FontPath     "/usr/share/fonts/latex-ttf-fonts"
        FontPath     "/usr/X11R6/lib/X11/fonts/defoma/CID"
        FontPath     "/usr/X11R6/lib/X11/fonts/defoma/TrueType"
EndSection
Section "Module"
        Load  "ddc"  # ddc probing of monitor
#       Load  "GLcore"
        Load  "dbe"
#       Load  "dri"
        Load  "extmod"
        Load  "glx"
        Load  "bitmap" # bitmap-fonts
        Load  "speedo"
        Load  "type1"
        Load  "freetype"
        Load  "record"
EndSection
Section "InputDevice"
        Identifier  "Keyboard0"
        Driver      "keyboard"
        Option      "CoreKeyboard"
        Option "XkbRules" "xfree86"
        Option "XkbModel" "pc105"
        Option "XkbLayout" "us"
EndSection
        Identifier  "Serial Mouse"
        Driver      "mouse"
        Option      "Protocol" "Microsoft"
        Option      "Device" "/dev/ttyS0"
        Option      "Emulate3Buttons" "true"
        Option      "Emulate3Timeout" "70"
        Option      "SendCoreEvents"  "true"
EndSection
        Identifier  "PS/2 Mouse"
        Driver      "mouse"
        Option      "Protocol" "auto"
Option          "ZAxisMapping"          "4 5"
        Option      "Device" "/dev/psaux"
EndSection
        Identifier      "USB Mouse"
        Driver          "mouse"
        Option          "Device"                "/dev/input/mice"
        Option          "Protocol"              "IMPS/2"
        Option          "Buttons"               "5"
EndSection
# Auto-generated by KNOPPIX mkxf86config
Section "Monitor"
        Identifier      "Monitor0"
        Option  "DPMS"  "true"
        VendorName      "PHL"
        ModelName       "PHL0001"
        HorizSync 30 - 63 # DDC-probed
        VertRefresh 50 - 120 # DDC-probed
        # These are the DDC-probed settings reported by your monitor.
        # 1280x1024, 75.0Hz; hfreq=79.98, vfreq=75.03
        ModeLine "1280x1024"    135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
        # 1024x768, 75.0Hz; hfreq=60.02, vfreq=75.03
        ModeLine "1024x768"      78.75 1024 1040 1136 1312  768  769  772  800 +hsync +vsync
        # 1024x768, 70.0Hz; hfreq=56.48, vfreq=70.07
        ModeLine "1024x768"      75.00 1024 1048 1184 1328  768  771  777  806 -hsync -vsync
        # 800x600, 85.0Hz; hfreq=53.67, vfreq=85.06
        ModeLine "800x600"       56.25  800  832  896 1048  600  601  604  631 +hsync +vsync
        # 800x600, 75.0Hz; hfreq=46.88, vfreq=75.00
        ModeLine "800x600"       49.50  800  816  896 1056  600  601  604  625 +hsync +vsync
        # 800x600, 60.0Hz; hfreq=37.88, vfreq=60.32
        ModeLine "800x600"       40.00  800  840  968 1056  600  601  605  628 +hsync +vsync
        # 640x480, 85.0Hz; hfreq=43.27, vfreq=85.01
        ModeLine "640x480"       36.00  640  696  752  832  480  481  484  509 -hsync -vsync
        # 640x480, 75.0Hz; hfreq=37.50, vfreq=75.00
        ModeLine "640x480"       31.50  640  656  720  840  480  481  484  500 -hsync -vsync
        # 640x480, 60.0Hz; hfreq=31.47, vfreq=59.94
        ModeLine "640x480"       25.17  640  648  744  784  480  482  484  509 -hsync -vsync
        # Extended modelines with GTF timings
        # 640x480 @ 100.00 Hz (GTF) hsync: 50.90 kHz; pclk: 43.16 MHz
        ModeLine "640x480"  43.16  640 680 744 848  480 481 484 509  -HSync +Vsync
        # 768x576 @ 60.00 Hz (GTF) hsync: 35.82 kHz; pclk: 34.96 MHz
        ModeLine "768x576"  34.96  768 792 872 976  576 577 580 597  -HSync +Vsync
        # 768x576 @ 72.00 Hz (GTF) hsync: 43.27 kHz; pclk: 42.93 MHz
        ModeLine "768x576"  42.93  768 800 880 992  576 577 580 601  -HSync +Vsync
        # 768x576 @ 75.00 Hz (GTF) hsync: 45.15 kHz; pclk: 45.51 MHz
        ModeLine "768x576"  45.51  768 808 888 1008  576 577 580 602  -HSync +Vsync
        # 768x576 @ 85.00 Hz (GTF) hsync: 51.42 kHz; pclk: 51.84 MHz
        ModeLine "768x576"  51.84  768 808 888 1008  576 577 580 605  -HSync +Vsync
        # 768x576 @ 100.00 Hz (GTF) hsync: 61.10 kHz; pclk: 62.57 MHz
        ModeLine "768x576"  62.57  768 816 896 1024  576 577 580 611  -HSync +Vsync
        # 800x600 @ 100.00 Hz (GTF) hsync: 63.60 kHz; pclk: 68.18 MHz
        ModeLine "800x600"  68.18  800 848 936 1072  600 601 604 636  -HSync +Vsync
        # 1024x768 @ 100.00 Hz (GTF) hsync: 81.40 kHz; pclk: 113.31 MHz
        ModeLine "1024x768"  113.31  1024 1096 1208 1392  768 769 772 814  -HSync +Vsync
        # 1152x864 @ 60.00 Hz (GTF) hsync: 53.70 kHz; pclk: 81.62 MHz
        ModeLine "1152x864"  81.62  1152 1216 1336 1520  864 865 868 895  -HSync +Vsync
        # 1152x864 @ 85.00 Hz (GTF) hsync: 77.10 kHz; pclk: 119.65 MHz
        ModeLine "1152x864"  119.65  1152 1224 1352 1552  864 865 868 907  -HSync +Vsync
        # 1152x864 @ 100.00 Hz (GTF) hsync: 91.50 kHz; pclk: 143.47 MHz
        ModeLine "1152x864"  143.47  1152 1232 1360 1568  864 865 868 915  -HSync +Vsync
        # 1280x960 @ 72.00 Hz (GTF) hsync: 72.07 kHz; pclk: 124.54 MHz
        ModeLine "1280x960"  124.54  1280 1368 1504 1728  960 961 964 1001  -HSync +Vsync
        # 1280x960 @ 75.00 Hz (GTF) hsync: 75.15 kHz; pclk: 129.86 MHz
        ModeLine "1280x960"  129.86  1280 1368 1504 1728  960 961 964 1002  -HSync +Vsync
        # 1280x960 @ 100.00 Hz (GTF) hsync: 101.70 kHz; pclk: 178.99 MHz
        ModeLine "1280x960"  178.99  1280 1376 1520 1760  960 961 964 1017  -HSync +Vsync
        # 1280x1024 @ 100.00 Hz (GTF) hsync: 108.50 kHz; pclk: 190.96 MHz
        ModeLine "1280x1024"  190.96  1280 1376 1520 1760  1024 1025 1028 1085  -HSync +Vsync
        # 1400x1050 @ 60.00 Hz (GTF) hsync: 65.22 kHz; pclk: 122.61 MHz
        ModeLine "1400x1050"  122.61  1400 1488 1640 1880  1050 1051 1054 1087  -HSync +Vsync
        # 1400x1050 @ 72.00 Hz (GTF) hsync: 78.77 kHz; pclk: 149.34 MHz
        ModeLine "1400x1050"  149.34  1400 1496 1648 1896  1050 1051 1054 1094  -HSync +Vsync
        # 1400x1050 @ 75.00 Hz (GTF) hsync: 82.20 kHz; pclk: 155.85 MHz
        ModeLine "1400x1050"  155.85  1400 1496 1648 1896  1050 1051 1054 1096  -HSync +Vsync
        # 1400x1050 @ 85.00 Hz (GTF) hsync: 93.76 kHz; pclk: 179.26 MHz
        ModeLine "1400x1050"  179.26  1400 1504 1656 1912  1050 1051 1054 1103  -HSync +Vsync
        # 1400x1050 @ 100.00 Hz (GTF) hsync: 111.20 kHz; pclk: 214.39 MHz
        ModeLine "1400x1050"  214.39  1400 1512 1664 1928  1050 1051 1054 1112  -HSync +Vsync
        # 1600x1200 @ 100.00 Hz (GTF) hsync: 127.10 kHz; pclk: 280.64 MHz
        ModeLine "1600x1200"  280.64  1600 1728 1904 2208  1200 1201 1204 1271  -HSync +Vsync
        # 1920x1200 @ 60.00 Hz (GTF)  hsync: 74.52; pclk: 193.16 MHz
        Modeline "1920x1200" 193.16  1920 2048 2256 2592  1200 1201 1204 1242  -HSync +HSync
EndSection
Section "Device"
        ### Available Driver options are:-
# sw_cursor is needed for some ati and radeon cards
        #Option     "sw_cursor"
        #Option     "hw_cursor"
        #Option     "NoAccel"
        #Option     "ShowCache"
        #Option     "ShadowFB"
        #Option     "UseFBDev"
        #Option     "Rotate"
        Identifier  "Card0"
# The following line is auto-generated by KNOPPIX mkxf86config
        Driver      "nvidia"
        VendorName  "All"
        BoardName   "All"
#    Option "RenderAccel" "true"
#    Option "AllowGLXWithComposite" "true"
    Option "TwinView"
    Option "SecondMonitorHorizSync"     "30-50"
    Option "SecondMonitorVertRefresh"   "60"
    Option "MetaModes" "1024x768, 640x480; 800x600, 640x480; 640x480, 640x480;"
    Option "TVStandard" "PAL-B"
#    Option "Xinerama" "0"
    Option "TwinViewOrientation" "Clone"
    Option "ConnectedMonitor" "CRT,TV"
#    Option "UseInt10Module" "true"
 Option "TVOutFormat" "SVIDEO"
#       BusID       "PCI:1:0:0"
EndSection
Section "Screen"
        Identifier "Screen0"
        Device     "Card0"
        Monitor    "Monitor0"
        DefaultColorDepth 24
        SubSection "Display"
                Depth     1
                Modes "1024x768" "800x600" "640x480"
        EndSubSection
                Depth     4
        EndSubSection
                Depth     8
        EndSubSection
                Depth     15
        EndSubSection
                Depth     16
        EndSubSection
                Depth     24
        EndSubSection
                Depth     32
        EndSubSection
EndSection
Section "DRI"
        Mode 0666
EndSection
I have tried commenting and unommmenting different parts under the "Device" section
Help.
Distro: Mandriva 2009.1
Vogateer
Post by Vogateer » Sat May 06, 2006 9:41 am
Man, I managed to do this ages ago, but I didn't have MythTV, so I didn't bother leaving it up and working. One thing I didn't use was a "Clone" setup, you might try "RightOf" just to see if that works for the orientation. Do you have both monitors turned on when you start up X? Well, I'm always raving about Gentoo's documentation, let's see if it helps you out at all:
http://gentoo-wiki.com/HOWTO_Dual_Monitors
That was the place I went to when I started to set my computer up to use dualscreen. I can go digging through my backups to see if I can find anything for you, but don't hold your breath on that one. I set the thing up to use the TV for one day, then never did it again.
Vim is beautiful
DaveQB
Post by DaveQB » Sat May 06, 2006 6:05 pm
Yeah I agree, Gentoo documentation is the best of any distro; the best part about Gentoo :P i ran it for a few months.
But I did find that page on my 5 hours of searching last night. Its the same as my config file posted. All info I find says I should use the settings I am using. Thats the frustrating part :evil:
Knopmyth comes XF86 still, so may be there's a "gotcha" somewhere there.
I think I will post on the Unofficial Nvidia forums.
DaveQB
Post by DaveQB » Sat May 06, 2006 6:14 pm
And its a TV and CRT not 2 CRT's.
Vogateer
Post by Vogateer » Sat May 06, 2006 11:35 pm
Sorry man, I'm looking at that config, and I'm not noticing anything that stands out. I haven't use XF86 for what seems like a year, so that may be part of the problem. I just managed to get modular Xorg working on an old iMac at work, so XF86 feels practically antiquated to me now. Good luck, I'm sure if you keep banging your head against it you'll finally get it up and running.
Vim is beautiful
DaveQB
Post by DaveQB » Sun May 07, 2006 7:36 am
Well I ended up conceding a small defeat and just enabled to TV-only setting. But now its just plain annouying me that I couldnt get it set up.
Just for the sake of it I want to know how to do it in case I need to do it for someone [or myself] at a later date. Plus, I am not one to give up and be defeated by a machine :twisted:
Perhaps its a limitation by the card I was trying it with, a GF4 MX4000. I will have a play with my 6600GT in my PC and see what i get.
