Show software
Simulcra
Show software
Post by Simulcra » Tue May 09, 2006 1:37 pm
Hey guy's love the show. Keep up the good work. I listen via the ogg podcast thank you so much for it.
I have long been interested in creating a podcast about alternative music. Can you recommend some SW packages that I should check out? I have used Ardour and that's cool and all, but is there anything that might be better?
Norm
thetza
Post by thetza » Sun May 14, 2006 1:17 am
I hear the tllts crew uses dynebolic, though I'm sure they use other tools as well.
Post by dann » Sun May 14, 2006 1:37 pm
This is the breakdown of the show software:
The streaming servers are running icecast2
We stream to icecast2 using muse on dynebolic.
I record the show using Audacity.
For call-out we use asterisk with one of the following clients: SJPhone, X-Ten lite or iaxcomm.
We also employ skype and have gizmo ready to go.
