Erik_
Post
by Erik_ » Tue Dec 21, 2004 5:32 pm
Great
it looks that your forum is running the latest release of phpbb 2.0.11 that is secure from the Sanity.a worm, which is taking advantage of Google to find other php/phpbb web sites to infect.
This is just one part of the secure IT process. Making sure your own systems are secured and up-to-date on what software and versions are running. If every would take such an approach, a lot less harm would spread across the internet. Computing is like taking care of a car, it needs constant attention, otherwire things will go haywire...
Erik
phpbb code to fix patch
http://www.phpbb.com/phpBB/viewtopic.php?t=240513
