BashPodder and DigitalLife.tv videocast
elgordo123
Post by elgordo123 » Fri Jul 28, 2006 1:12 pm
For some reason bashpodder is not downloading digitallife.tv video podcast.
I am using the Divx link:
http://rssnewsapps.ziffdavis.com/audiob ... V.xvid.xml
It looks like it see's the first one in the list, but doesn't see any others, As of today, 7/28/2006 temp.log will see episode 66, but it doesn't appear to be parseing through and getting any others. (i.e. the latest, 80). Downloaded bashpodder.shell and the parse file today too, same results. My other podcasts work fine, tllts and twit.
I thought I'd post here instead of emailing linc incase someone has already seen this and found a fix for it.
Thanks in advance.
Re: BashPodder and DigitalLife.tv videocast
Post by Gomer_X » Mon Jul 31, 2006 9:09 am
elgordo123 wrote:For some reason bashpodder is not downloading digitallife.tv video podcast.
Feed looks OK as of this moment.
elgordo123 wrote:It looks like it see's the first one in the list, but doesn't see any others, As of today, 7/28/2006 temp.log will see episode 66, but it doesn't appear to be parseing through and getting any others. (i.e. the latest, 80).
What do you mean by "see" the first on the list? The first should be the most recent episode, which is episode 81 as of today.
When are you looking at temp.log? Temp.log will be deleted before bashpoder finishes, and changes throughout the run.
You can copy bashpodder.shell to another name (cp bashpodder.shell hackpodder.shell && chmod +x hackpodder.shell), then delete the lines
    if ! grep "$url" podcast.log > /dev/null
        then
        wget -t 10 -U BashPodder -c -q -O $datadir/...
    fi
Then delete every line of the script after
done <bp.conf
Run this script, and it will generate a temp.log with the URLs of everything bashpodder is trying to download (without downloading anything).
elgordo123 wrote:Downloaded bashpodder.shell and the parse file today too, same results.
You should have bashpodder.shell and parse_enclosure.xsl in the same directory. It'll work without the .xsl file, but not as well. You also must have xsltproc installed on your system.
elgordo123
Post by elgordo123 » Mon Aug 07, 2006 7:24 pm
Thanks. I think the problem was that I didn't have xsltproc installed. After I installed that it downloaded everything fine.
