Best Distro for Web, FTP, and Mysql Server
canadiantechie
I'm contemplating chaning the my software. Currently I use Fedora and with my limited resources (system and financial) I would like to fine a distro thats lightweight and fast, but still powerful enough for all my needs.
Guest
My entire website and gateway runs off a p3 450 with 192 megs of ram. I run mysql and lots pf custom php among other things on Slackware. Never had a problem.Patrick wrote:My dad gave me his old machine:
Emachine 466mhz Celeron with 64 meg of memory. I'm going to put Slackware 10.1 with xfce and run apache. It'll be my web blog site. I'm doing the install this weekend.
Guest
My notebook is a PII 366Mhz with 256MB RAM. It runs Fedora Core 3 and has both server (apache/mysql/php) and desktop (x.org, multimedia etc) stuff.
Why would you want to leave Fedora? It's not a good idea to get into oddball distributions that are irrelevant to the real world. If you rent a dedicated, guess what OS it'll have? If you deal with a big customer, what is the upgrade path to a stable enterprise fork?
In any case the performance issues on Fedora can be resolved by downloading the source code for x.org from cvs and recompiling it. That will make your computer fly.
Best,
Gordon H.
Best,
Gordon H.
I think you have missed the point - for a lightweight server box, a desktop oriented, bleeding edge distribution is probably not the best idea. I would be very surprised if you can find a dedicated server company running Fedora - more likely it will be RedHat, but they are very different things, and the likelyhood is that RedHat has been chosen for its support options rather than the OS. Of course, you may find that it is running DebianAnonymous wrote:My notebook is a PII 366Mhz with 256MB RAM. It runs Fedora Core 3 and has both server (apache/mysql/php) and desktop (x.org, multimedia etc) stuff.
If you're running your own server, then you are probably not wanting to fork out for a support contract, and so you can run what you like. If you want to run a RedHat option, then you'd probably go for CentOS. However, most people do end up using Slackware/Debian/Gentoo because they are a) customisable and b) have a lightweight default install.
mrben,mrben wrote: I think you have missed the point - for a lightweight server box, a desktop oriented, bleeding edge distribution is probably not the best idea. I would be very surprised if you can find a dedicated server company running Fedora - more likely it will be RedHat, but they are very different things, and the likelyhood is that RedHat has been chosen for its support options rather than the OS. Of course, you may find that it is running Debian
You're spot on. Fedora is a nice distro if you have a fast machine with a decent sized hard drive for the 3 gig install. I use fedora on my mythtv box because setting up mythtv is much easier with apt-get with everything pre-compiled and dependency checked. I got apache running on this machine (466mhz, 64 meg ram and 10 gig hard drive) without any issues so far. For shits and giggles I tried to install fedora and it bombed out about 10 minutes in. Slackware 10.1 installed like a champ. No burps or farts at all!
Guest
Unfortunately MrBen you have blown your credibility with the above. The first is simply untrue -- I suggest you look at EV1, ServerBeach, etc.mrben wrote:
(snip)
(snip)
Based on what source or metric do you assert "most people do end up using Slackware/Debian/Gentoo." This is not borne out by distro download counts, netcraft, or any other objective measure. I think you just made it up.
Guest
Uh, dude, apt-get works on Fedora. Keep your skills current.Patrick wrote: mrben,
I hadn't before, I have now. Both of these companies are running RedHat Enterprise Linux not Fedora. As I said before, Fedora and RHEL are different thingsAnonymous wrote: Unfortunately MrBen you have blown your credibility with the above. The first is simply untrue -- I suggest you look at EV1, ServerBeach, etc.
I didn't just 'make it up', neither did I use any published metrics. I based it on my experience talking with Linux users over the past 5 years, and the fact that, from what I've seen, hosting companies tend to offer either RedHat (remember, != Fedora) or Debian (which is the choice that ServerBeach offer).Based on what source or metric do you assert "most people do end up using Slackware/Debian/Gentoo." This is not borne out by distro download counts, netcraft, or any other objective measure. I think you just made it up.
Actually - I suspect that many people 'in the know' don't use Linux at all, but use one of the BSDs instead, when it comes to servers.
If you have metrics to prove otherwise, by all means post them.
I might suggest Damn Small Linux if system resources are a big issue. If its like a +300mhz machine I might suggest Mandrake. I run it on my personal workstation and my samba server foot rest
Check out my page!
You can run just about any distro on your servers and be fine. I run Debian on my servers for two reasons:
1. I don't have to worry about changes in my distribution due to changes in the supporting company's marketing strategy, etc.
2. Debian does a good job providing security updates. (As do others.)
On my desktop and other personal machines, I like to play with the newest software, but on my servers I want stability and security above all else. I get that from Debian.
