Trixbox 2.0 login
mxc
Trixbox 2.0 login
Post by mxc » Tue Jan 23, 2007 3:55 pm
Hi there,
I heard your discussion around the trixbox login on your last podcast. My understanding is there are two logins needed now.
1) The usualy maint/password for the admin section and,
2) then your forum username/password for the user section.
What bothers me about this is that trixbox front-end almost "calls home" when you login. I haven't had time to get more familiar with this yet but I am concerned about having to go out over the internet every time you login to the user section. I could be speaking under correction and maybe there is a way round this but my first impression with this move is not good.
Does anyone have any info on this? Is it necessary?
Post by dann » Tue Jan 23, 2007 5:16 pm
This is something I've been meaning to get back too. I have not fully checked it out and only found this out after searching around their forums. It seems like a very bad idea to have a login to a system hosted elsewhere the same as your login to the developers forum. I guess this means anyone subscribed to the board could log into my user interface if they could get to it.
mxc
Post by mxc » Tue Jan 23, 2007 10:09 pm
Thats a good point. I think its just fonality's way of gathering statistics. One could look through the code and see what else it is sending through to their servers but I a warning from Fonality would have been nice
