What in your bp.conf file?
Ryochan7
Post by Ryochan7 » Thu Jun 16, 2005 9:14 pm
That post above is mine. I didn't notice that I wasn't logged in. Sorry.
Linux User #357977
LUGOP is awesome
Post by Gomer_X » Fri Jun 17, 2005 7:43 am
I'm pretty new to this so I've got mostly a stock bp.conf. I've removed LUGRadio (I mirror for them and don't need Bashpodder to get the file) and TLLTS (I grab it manually as soon as it comes out).
Here are a few I've added:
History accoring to Bob - a short history lesson every day
http://www.summahistorica.com/podcast/rss.xml
Laid-back - some funky music
http://www.laid-back.be/laidback.xml
Learn a Song a day! - old, boring folk songs
http://www.manythings.org/songs/rss.xml
Tokyo Calling - a teacher in Japan talks about living in Japan
http://tokyocalling.org/index.xml
Hope this helps someone. I'm looking forward to checking out links from other people.
Ryochan7
Post by Ryochan7 » Sat Jun 18, 2005 10:36 am
Thanks for recommending Tokyo Calling, Gomer_X. I like hearing almost anything about Japan, especially when it is from someone who is currently living in Japan. I have only listened to episode 16, so far, but I will keep this in my bp.conf file for a while.
Linux User #357977
LUGOP is awesome
danheneise
Post by danheneise » Thu Jul 07, 2005 6:27 pm
i recently downloaded bash podder, now i gotta learn how to use it :wink:
Post by Gomer_X » Fri Jul 08, 2005 10:07 am
Ryochan7 wrote:Thanks for recommending Tokyo Calling, Gomer_X. I like hearing almost anything about Japan, especially when it is from someone who is currently living in Japan. I have only listened to episode 16, so far, but I will keep this in my bp.conf file for a while.
It seems kinda spotty. I wish he would do more on Japan and Japanese culture, but it's definitely worth a listen.
The last one (episode 18 ) was kinda odd, but it seems he's got some new things coming up.
Post by Gomer_X » Fri Jul 08, 2005 10:24 am
danheneise wrote:i recently downloaded bash podder, now i gotta learn how to use it :wink:
It's not too hard. Helps if you know a little BASH scripting. You should have bashpodder.shell and bp.conf in the same directory.
If you just run it (type ./bashpodder.shell), it should take off and download everything. You may want to copy bp.conf to bp.conf.old or something and edit bp.conf. You'll see that the conf file is just a list of URLs to the RSS feed of the podcast. I delted the URLs for LUGRadio and TLLTS because I already had the files and didn't want to download them again.
It might be wise to narrow your list at first and then build it back up unless you want to download 100s of megs at once. There are a lot of podcasts in the defualt bp.conf.
Once I got it working, I put it in my crontab, and it just runs every night.
I just did 'crontab -e' and added the line
10 23 * * * /home/jeff/audio/pod/bashpodder.shell
and that was it. That sets a cron job to start bashpodder at 11:10 PM (that's where the 10 23 comes from) every night. You'll have to put in the path to your bashpodder.shell unless it's actually in /home/jeff/audio/pod.
Holla back if you need more help.
