Judland wrote:yum install <app name>
apt-get install <app name>
you get the idea.
Technically, I guess yum is "easier" 'cause it takes fewer keystrokes.
While I agree that this type of install is far easier than compiling from source, it is still way beyond a general Windows user.
Taking installation out of the equation, if we compared a default windows install next to a default Linux install (just about any distro) right off the bat, I do think Linux has an edge because of the sheer number of standard applications most general computer users would use. Be it KDE or Gnome, just like moving to OS X from Windows, it will take a bit of time to get used to the interface, but there are a lot of similarities.
Software installation is a different story. Windows users have been conditioned to either purchase software at a store or download an executable installation file of the internet. Auto-running of the installation cd makes this almost a no-brainer.
I still think Linux has a leg up here in one respect. Instead of having to comb the internet or store shelves for a piece of software, Linux users, particularly those using apt or yum with a graphical tool like synaptic, have a host of repositories they can choose software from. The downside? For the general user the layout of these utilities still sucks.
I'm going to smack around synaptic because that is the only one I am really familiar with. Synaptic has a category view which helps to narrow the search but I don't see a need for there to be three different headings per category. The general user does not care or want a games, games (non-free), games (universe) etc. They just want games.
I don't think apps should cross over in categories, that is if I am searching through the games listings I should not see game development tools, libraries for creating specific types of games, etc. Just as I would expect to not see xevil in the development listings.
I still stand behind the idea that wizards should be included in these applications. The first time I start synpatic it should explain the software and then ask me if I want to add additional repositories, particularly if those repositories are not enable by default. Explain why universe and multivers are not included by default. Give me the choice to enable these right from the get go.
I don't think any modern distro, geared towards the desktop user, should come cripled! There is no reason why mp3, video codec and flash support should not be included by default. It's plain stoopid and unneccessary to make me manually add respositories and then have to hunt down the necessary packages. I respect the desire to promote open technologies, but not including mp3 in Fedora or Ubuntu is not going to increase ogg usage when a simple addition to the repository fixes that.
This should be part of the install. Do you want mp3 support? Ok, understand these licensing agreements. Do you want video codecs? Understand these licensing agreements. Do you want flash support? Ok understand these licensing agreements.
Ah damn-it, now I lost my train of thought.
