http://koolu.com/Koolu-WE-Appliance/WE-Phone.html
But the super interesting part follows...The W.E.™ Phone:
Open Source and it works everywhere you do
Want to run your business efficiently and without a hitch no matter where in the world you happen to be? At home or on the road, you'll come to appreciate the W.E.™ Phone for having all the features you need to help you stay connected and at the top of your field. As it's open source, you'll be able to customize the W.E.™ Phone to suit your business needs, including higher levels of security and encryption if necessary.
Huge savings, both in time and money
A tri-band GSM Wi-Fi enabled device, the W.E.™ Phone will put you in communication with your clients and staff via inexpensive or free VoIP calls, which represents huge savings over conventional calls. Its GPS functionality can help you track places, people, and assets, truly allowing you to maximize the use of your time.
Fast, powerful, full-featured, and plenty of storage for all your needs
A high resolution touchscreen is a must-have for fast and easy data entry and retrieval. USB host and device support is a given, so you'll be able to add peripherals and retrieve/reconcile data with ease whether you're an at-home or on-the-road warrior. Or both.
Storage of 256 MB NAND flash is included, and you can add up to 8GB with the MicroSD card expansion bay for more intensive data storage requirements such as multimedia. The W.E.™ Phone's fast 400 MHz speed means you can leave larger computing appliances at home or even dispense with them completely. It is entirely possible to conduct your business from the palm of your hand. Wouldn't that be a smart way for you to do business?
Low-cost and eco-friendly
And what's more, you can be kind to the earth and your wallet at the same time. Going green has never been easier! All Koolu W.E.™ products are low-power consuming, RoHS compliant appliances. Getting into business with a single low-cost, extremely low wattage computer appliance will reduce your carbon footprint and your business expenses. We're committed to long-term sustainability and success for you and OUR PLANET.
--As a side note, Koolu never sent me the free Koolu appliance they promised me a while ago.How to get your W.E.™ Phone:
(1) Sign up for Google Apps (a great GREEN business tool, and it's FREE!)
(2) Contact your local wireless ISP
The Koolu W.E.™ Phone will only be available to Google Apps users, and may be obtained from our eco-friendly business partners worldwide for the great price of only C$99 along with a VoIP service contract. Contact your local ISP today to inquire about getting your open source W.E.™ Phone. A limited initial release will occur in the second quarter, with a wide-spread release of the W.E.™ Phone slated for the Summer of 2008.
The W.E.™ Phone will be available to developers this March, and to consumers in the Summer of 2008.
