Dann, did you give Puppeee a try?
Post by greggh » Thu Apr 10, 2008 3:05 am
http://www.linux.com/feature/131070
There's also eeeXubuntu, EeeDora, ZenEee, and EeePCLinuxOS
http://murga-linux.com/puppy/viewtopic. ... 36&t=25896
Re: Dann, did you give Puppeee a try?
Post by dann » Fri Apr 11, 2008 4:11 pm
Yes I did try eeePuppy. It's a nice little distro and things were working great. I booted it from flash. I plan to give it soom more testing this weekend, but I did like what I saw so far. I want to see if I can get the webcam working. Supposedly it will...
mowestusa
Post by mowestusa » Sun Apr 13, 2008 7:02 pm
dann wrote:Yes I did try eeePuppy. It's a nice little distro and things were working great. I booted it from flash. I plan to give it soom more testing this weekend, but I did like what I saw so far. I want to see if I can get the webcam working. Supposedly it will...
Dann, you might really like it now that it is based on Slackware, and I believe you can install slack packages on it. :-)
Post by dann » Sun Apr 13, 2008 9:06 pm
I used the eeePuppy to rid my eeePC of the user partition and resize the main partition with gparted to reclaim the extra space used by the unionfs. It was a breeze. eeePuppy is fantastic, I will add. I look forward to playing around with a lot more!
I also want to give eeeXBuntu a whirl off the flash.
Post by greggh » Mon Apr 14, 2008 5:23 pm
dann wrote:I also want to give eeeXBuntu a whirl off the flash.
Didn't you make it clear on the last show that you absolutely hate the new xfce, that you think it's a terrible project, and that the developers are awful people? :wink:
