Downloading Show Files Directly
- mowestusa
Hi guys,
I'm sure there is an easy way to do this, but I'm not finding it. I'm on vacation right now, on a windows machine only, and I can't seem to download the show audio files in Firefox or in IE.
Usually on my Linux boxes, I use bashpodder and that works great. If I need to down load the shows directly to the desktop, I copy the web address that comes up when you click on MP3 or OGG. Then I use wget. When I try to right click on those links, and chose "Save Target As" all I get is a html or php file. Any ideas? Normally for other shows I can do a direct download of the files with "Save Target As", but with the special mirror network for tllts, this must not work in the browsers.
Thanks for the help.
Re: Downloading Show Files Directly
These are the direct links:
http://www.tllts.org/audio/tllts_252-07-02-08.ogg
http://www.tllts.org/audio/tllts_252-07-02-08.mp3
Just change the show and date information for the episode you want.
- mowestusa
Thanks Pat,Patrick wrote:These are the direct links:
I had to create a quick HTML document with a <a href=> tag, open it in Firefox then choose "Save Target As" and now I'm in business, and downloading right now. Thanks for letting me get my TLLTS fix on vacation.
I usually just keep doing it over and over. After about the 5th time, you get the actual file rather than the HTML page.mowestusa wrote:When I try to right click on those links, and chose "Save Target As" all I get is a html or php file. Any ideas? Normally for other shows I can do a direct download of the files with "Save Target As", but with the special mirror network for tllts, this must not work in the browsers.
I don't know why.
That's odd. I never have any problems unless the file is missing from one of the mirrors. In fact, here I am grabbing the last show:Gomer_X wrote:I usually just keep doing it over and over. After about the 5th time, you get the actual file rather than the HTML page.mowestusa wrote:When I try to right click on those links, and chose "Save Target As" all I get is a html or php file. Any ideas? Normally for other shows I can do a direct download of the files with "Save Target As", but with the special mirror network for tllts, this must not work in the browsers.
I don't know why.
That's because you're using my mirror, which is the best.Linc wrote:That's odd. I never have any problems unless the file is missing from one of the mirrors. In fact, here I am grabbing the last show:Gomer_X wrote:I usually just keep doing it over and over. After about the 5th time, you get the actual file rather than the HTML page.mowestusa wrote:When I try to right click on those links, and chose "Save Target As" all I get is a html or php file. Any ideas? Normally for other shows I can do a direct download of the files with "Save Target As", but with the special mirror network for tllts, this must not work in the browsers.
I don't know why.
Actually I should have been more clear. This only happens when I try to download the show in IE by going in from the TLLTS front page and right-click the MP3 link and do "Save target as." It only happens sometimes.
- LinuxMint-4
I always used this link to download shows directly.
http://feeds.feedburner.com/TheLinuxLinkTechShowMp3Feed
