So, I'm having issues with Kdenlive dropping the audio before the video is complete. Like, I'm importing an mp3 let's say 4mins and applying photos for that 4 mins aswell and exporting to dv avi or mpeg or anything. It plays the video full length but consistantly, no matter what mp3 I use, cuts the sound about 35 to 40 second before the end of the clip. What do I do to fix it? Anyone had this issue?
EDIT: Actualy, this is important to know, it doesn't matter if there is a photo or video to go with the audio. It just drops. I can just use the audio clip and export to video and it will still drop the audio but play through.
You know what, it may be that I've been adding the mp3s to audio/video tracks and not audio tracks. I'll try it again. It's exporting.... 67%... 85%.. crap..it still cuts the audio short.
KDEnlive dropping audio
MattKingUSA
MattKingUSA
Re: KDEnlive dropping audio
AH! I got it, I changed the defaul video project from "DV NTSC" to "DV PAL". Mwahaha!!! It works!!!
Solved!
Solved!
