drbl/clonezilla is the open source turnkey replacement for norton ghost enterprise. It is awesome thin client server. it is great also for pxe booting systems to different net installs, pxeboot for imaging systems. will do multi-cast distribution of saved images. pxeboot to memtest, pxeboot to freedos and may other things.. (i know you can hack the equivalent.) Redhat/centos have their own equivalent built in. Mandriva I think also has their own. All distros i guess do at that.
I had a problem with the original install, but all is well...
I found a new set of instructions and redid the server from scratch. Everything is working fine now. I must of had a bad repo. Can not wait to try ig nics!!!
drbl/clonezilla
