Linux for the blind.
Post by eddie » Wed Jan 28, 2009 8:43 am
I just downloaded the new Adriane Knoppix version of linux and it seems to be very oriented towards the blind. it is a live cd so you do not have to install it. As long as you put it into a machine with a working compatible sound and speakers, it talks everything including the text menus available at boot time to run just special programs. It took me for a loop till I realized it's intentions. You can go to http://distrowatch.com/table.php?distribution=knoppix. I went to a faster mirror to download it though. I highly recommend it as one of the options you or someone you know who is blind to get into computing.
MattKingUSA
Re: Linux for the blind.
Post by MattKingUSA » Fri Jan 30, 2009 9:49 am
That's awesome. what does the default theme look like?
Post by dann » Fri Jan 30, 2009 10:06 am
MattKingUSA wrote:That's awesome. what does the default theme look like?
:lol:
Post by eddie » Fri Jan 30, 2009 11:22 am
lxde sort of icewm like
MattKingUSA
Post by MattKingUSA » Fri Jan 30, 2009 11:23 am
It sounds like a really nice setup. I cant wait to SEE it. Ermmhahaha yes....
