(SOLVED) MythStreamTV Question
kwisher
Post by kwisher » Thu Feb 26, 2009 12:58 pm
Hello All,
I have installed MythStreamTV using the instructions here (http://ubuntuforums.org/showthread.php? ... thstreamtv) and using the attached file. When I try to start the stream from Mythweb I receive the following error : An unknown module was specified.
I see some errors from the install script. I have include the text from the terminal.
    MythStreamTV Directory         : /usr/share/mythtv/mythstreamtv
    MythWeb HTTP Directory         : /usr/share/mythtv/mythweb
    MythWeb HTTP Service Account   : www-data
    MythStreamTV Server Address    :
    MythStreamTV Server Port       : 8001
    MythStreamTV Stream Admin Port : 8002
    MythStreamTV User:Group        : mythtv:mythtv
    MythTV Recordings Directory    : /var/lib/mythtv/recordings
    Path to where vlc is installed : /usr/bin/vlc
Installing MythStreamTV.........
.... Checking MythWeb Compatablity: .... Installing /usr/share/mythtv/mythstreamtv/mythstreamtv.sh: cat: /usr/share/mythstreamtv/mythstreamtv.sh: No such file or directory
Success
.... Installing /usr/share/mythtv/mythstreamtv/mythstreamtvactive.sh: cat: /usr/share/mythstreamtv/mythstreamtvactive.sh: No such file or directory
Success
.... Installing /usr/share/mythtv/mythstreamtv/mythstreamtvctrl.sh: cat: /usr/share/mythstreamtv/mythstreamtvctrl.sh: No such file or directory
Success
.... Installing /usr/share/mythtv/mythstreamtv/mythstreamtvstop.sh: cat: /usr/share/mythstreamtv/mythstreamtvstop.sh: No such file or directory
Success
.... Installing /usr/share/mythtv/mythstreamtv/ivtv-tune.sh: cat: /usr/share/mythstreamtv/ivtv-tune.sh: No such file or directory
Success
Creating StreamTV Diretory's in MythWEB...
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/handler.php: cat: /usr/share/mythstreamtv/modules/handler.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/init.php: cat: /usr/share/mythstreamtv/modules/init.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/confirm.php: cat: /usr/share/mythstreamtv/modules/confirm.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/createfile.php: cat: /usr/share/mythstreamtv/modules/createfile.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/selectstream.php: cat: /usr/share/mythstreamtv/modules/selectstream.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/default/createfile.php: cat: /usr/share/mythstreamtv/themes/createfile.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/default/menu.php: cat: /usr/share/mythstreamtv/themes/menu.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/default/confirm.php: cat: /usr/share/mythstreamtv/themes/confirm.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/default/selectstream.php: cat: /usr/share/mythstreamtv/themes/selectstream.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/default/welcome.php: cat: /usr/share/mythstreamtv/themes/welcome.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/compact/createfile.php: cat: /usr/share/mythstreamtv/themes/createfile.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/compact/menu.php: cat: /usr/share/mythstreamtv/themes/menu.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/compact/confirm.php: cat: /usr/share/mythstreamtv/themes/confirm.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/compact/selectstream.php: cat: /usr/share/mythstreamtv/themes/selectstream.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/compact/welcome.php: cat: /usr/share/mythstreamtv/themes/welcome.php: No such file or directory
Success
ln: creating symbolic link `/usr/share/mythtv/mythweb/modules/streamtv/tmpl/lite/compact': File exists
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/wap/createfile.php: cat: /usr/share/mythstreamtv/themes/wap/createfile.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/wap/menu.php: cat: /usr/share/mythstreamtv/themes/wap/menu.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/wap/confirm.php: cat: /usr/share/mythstreamtv/themes/wap/confirm.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/wap/selectstream.php: cat: /usr/share/mythstreamtv/themes/wap/selectstream.php: No such file or directory
Success
.... Installing /usr/share/mythtv/mythweb/modules/streamtv/tmpl/wap/welcome.php: cat: /usr/share/mythstreamtv/themes/wap/welcome.php: No such file or directory
Success
.... Checking MythWeb Installation: Not required, skipping
.... Checking MythWebWap Installation: Not required, skipping
.... Fixing up file permissions: ln: creating symbolic link `/usr/share/mythtv/mythweb/modules/streamtv/includes/includes': File exists
Scanning php files in /usr/share/mythtv/mythweb
Can someone please help me with this problem?
TIA
DaveQB
Re: MythStreamTV Question
Post by DaveQB » Thu Feb 26, 2009 10:24 pm
Clearly you are missing files in
run:
ls -l /usr/share/mythtv/mythstreamtv
And show us the output.
Distro: Mandriva 2009.1
kwisher
Post by kwisher » Thu Feb 26, 2009 11:14 pm
DaveQB wrote:Clearly you are missing files in
run:
 # ls -l /usr/share/mythtv/mythstreamtv
total 0
-rwxrwxrwx 1 mythtv mythtv 0 2009-02-26 12:52 ivtv-tune.sh
-rwxrwxrwx 1 mythtv mythtv 0 2009-02-26 12:52 mythstreamtvactive.sh
-rwxrwxrwx 1 mythtv mythtv 0 2009-02-26 12:52 mythstreamtvctrl.sh
-rwxrwxrwx 1 mythtv mythtv 0 2009-02-26 12:52 mythstreamtv.sh
-rwxrwxrwx 1 mythtv mythtv 0 2009-02-26 12:52 mythstreamtvstop.sh
DaveQB
Post by DaveQB » Fri Feb 27, 2009 12:52 am
That's bizzare!
The files are there. Have you run it again ? Maybe they have since been installed .. :?:
ls -l /usr/share/mythstreamtv/mythstreamtvactive.sh
Is it really there ? I have copied and paste to make sure there is not typo.
Investigate those files and that installer you are running..
mikeh
Post by mikeh » Fri Feb 27, 2009 1:47 am
Never used mythstreamtv but from the looks of your errors it seems that it is trying to copy the files into various directories in /usr/share/mythtv
The ls listing you produced shows the files in the target directory, but they are all zero bytes in size.
Are you running the install script as root?
kwisher
Post by kwisher » Fri Feb 27, 2009 4:48 pm
mikeh wrote:Never used mythstreamtv but from the looks of your errors it seems that it is trying to copy the files into various directories in /usr/share/mythtv
I installed using sudo as the how-to instructed. After I read your post I installed again as root. Same results. Any other suggestions?
mikeh
Post by mikeh » Fri Feb 27, 2009 8:31 pm
So did you do this from the terminal after downloading the file. (I apologize if this is exactly how you did it, but I want to make sure).
cd /
sudo tar -xzvf <path_to_package>/mythstreamtv_1.30-11-amk.tar.gz
cd /usr/share/mythstreamtv
sudo nano ./install.sh  (make your edits and save)
sudo ./install.sh
I am wondering if you did the tar from the root of your file system. Just by untaring the gz file from root you should have the /usr/share/mythstreamtv directory populated with the files you listed in a previous post, but they shouldn't be zero byte.
kwisher
Post by kwisher » Sat Feb 28, 2009 12:55 pm
mikeh wrote:So did you do this from the terminal after downloading the file. (I apologize if this is exactly how you did it, but I want to make sure).
cd /
sudo ./install.sh
No I did not. I downloaded and uncompressed to my desktop and installed from there via the terminal. I wasn't sure it was safe to do anything in the /root folder.
mikeh
Post by mikeh » Sat Feb 28, 2009 1:16 pm
Shouldn't be a problem. Doing the untar from / will put all the files in the proper location. It won't kill anything. The only thing it will do is overwrite those zero byte files which you want anyways.
I would do the install as they list and see if that solves your problem. Hopefully that will do it!
kwisher
Post by kwisher » Sat Feb 28, 2009 2:12 pm
That was the solution. Thanks so much for your help. I guess next time I will follow the instructions exactly as they are written.
mikeh
Post by mikeh » Sat Feb 28, 2009 3:35 pm
Glad that was it!
