Do you set your system clock to UTC
Is your srver set to UTC or your TimeZone?
UTC
7
58%
My Timezone
4
33%
Some other Timezone
0
No votes
What is a timezone (I'm american, we just look at the clock)
1
8%
Total votes: 12
Post by dann » Wed Mar 23, 2011 8:17 pm
Well let's hear it!
hen770
Re: Do you set your system clock to UTC
Post by hen770 » Mon Apr 11, 2011 5:16 pm
as far aa i know, you should set to UTC only if you don't have a windows at dual-boot.
by UTC i mean the BIOS clock, and linux byitself (through the timezone settings it has) do the convrtion to the local time.
Claudio
Post by Claudio » Mon Apr 18, 2011 11:59 am
hen770 wrote:as far aa i know, you should set to UTC only if you don't have a windows at dual-boot.
This is how I have it done since I'd stopped dual-booting on my PCs. The only other machine that was still left as a dual-boot was my old iMac G5 running OS X and Ubuntu but that has since died. On that machine, I do believe that I told it to use UTC but I can't recall correctly since it's been quite a while. But yes, overall I have it set to UTC as you stated.
Image Image
