This is baffaling to me. We have two quicktime streaming servers at work. They want to broadcast out from the server using Quicktime Broadcaster running on a G5. Everything works fine internally. Externally is another matter.
I cannot get the stream using Quicktime or RealPlayer from my house on the Powerbook. But, I can get the stream using vlc on Linux or vlc on OS X. WTF? Quicktime does a 10 second countdown and hangs at "switching tranports."
I don't think this is a firewall issue as I had our IU open all ports to the server. That did not make difference. Besides, vlc works, so why would it be a firewall issue.
What's perplexing is that this is apple technology and it will not even work with itself!
You can take a look for yourself: rtsp://stream.slsd.org/test
Streaming Server Problem
