;ok, call me a newb, but i am at a loss as to the "proper" way to install and/or configure bashpodder.
;i understand that i will have to schedule bashpodder to run by configuring it in a crontab (i can RTM for that), what i don't know is where to place the script (and its associated files) or where it will place the downloaded files and whether i can change that.
;is there any "official" documentation on how bashpodder works, how to configure it, etc? if not, i would like to figure this out and write some.
;treehead
bashpodder HOWTO?
bashpodder HOWTO?
I have not played with Linc's script yet (but will soon) but I seem to recall the last time I looked at it that there is a data directory variable or something within the script. You may want to look through the script itself because I think that's where you set it. Just change it whatever you want. As for where to save it, I would just save the script in your home directory and then have cron run it every so often.
datadir
;yeah, i saw that variable:Chess wrote:...I looked at it that there is a data directory variable or something within the script....
# datadir is the directory you want podcasts saved to:
datadir=$(date +%Y-%m-%d);i was wondering if there's a "standard" directory to house shell scripts in slackware (or any linux in general).Chess wrote:As for where to save it, I would just save the script in your home directory and then have cron run it every so often.
;treehead
Re: datadir
There are a whole bunch of people that have made that change. You can find their modified versions of the script with that change and a lot of other ideas as well at: http://linc.homeunix.org:8080/scripts/b ... ntributed/treehead wrote:actually, i'd like to have a separate directory for every podcast, where they can accumulate with each successive download.
;treehead[/quote]
Well, the standard (which not many people actually use anymore) is to create a "bin" directory under your home directory and use that to store the scripts you created.
ah-ha...
;gotcha. thanks.
;treehead
;treehead
