How to make XMMS default for .pls streams
- gordonmarkus
Alright all,
Another brain teaser for you, although I'm sure that you will know this without too much effort.
The communal pc in our shared house is now running slack 10.2 and everything is great, the win2k box could be heading for retirement but there are 2 minor obstacles that I need to sort out first...
1. The default player for .pls (streaming mp3 from shoutcast etc) files at the moment is xine, which is ok but when you click on a stream the web browser window becomes the xine window which is not great. I have downloaded and setup xmms, and I'd like to make it the default player for .pls or anything musical really as it seems a more pleasant application.
2. My housemate used to use a tool called 'bitlord' on the win2k box for downloading football matches (honestly!) - is there a comparable application for linux that you could recommend?
As always - thanks for your help.
-Gordon.
-Gordon.
stupid is as stupid does (and that'd be me most of the time!)
Re: How to make XMMS default for .pls streams
You're talking about a bittorrent client right? Personally I like azureus:gordonmarkus wrote: 2. My housemate used to use a tool called 'bitlord' on the win2k box for downloading football matches (honestly!) - is there a comparable application for linux that you could recommend?
http://azureus.sourceforge.net/
It's coded in java and thus cross platform.
If you're using KDE 3.4 as your desktop environment you can right-mouse click on the stream, choose Open With, select XMMS and check the box that makes the selection the new default.gordonmarkus wrote: 1. The default player for .pls (streaming mp3 from shoutcast etc) files at the moment is xine, which is ok but when you click on a stream the web browser window becomes the xine window which is not great. I have downloaded and setup xmms, and I'd like to make it the default player for .pls or anything musical really as it seems a more pleasant application.
- gordonmarkus
Hi,
Thanks for the advice - it's all looking good now.
Only 1 thing still outstanding - making xmms default, in firefox there's no 'open with option' with the right click. There is this option with konqueror, but I can't find a check box to set it as default.
It's not a major thing, but if anyone knows how I should be doing this it'd be awesome.
Thanks again
-Gordon.
Thanks again
-Gordon.
Ah, yes. Sorry... I didn't lead you quite down the right path there.
Here's how I do it:
http://www.virtualsky.net/kde-default.htm
Here's how I do it:
Nice, I'd like to see more examples in video/flash format. Good job.Judland wrote:Ah, yes. Sorry... I didn't lead you quite down the right path there.
Here's how I do it:
What are you using to make those tutorials? The are really nice!Judland wrote:Thanks, Dann. I like this way of tutorials, too.
I've made a few now for the office, as many people, even though they use PC every day, don't know how to do some of the simpler things... like book an appointment in their e-mail calendar.![]()
The visual tutorials seem to be popular.
- gordonmarkus
A little program called "Wink" http://www.debugmode.com/wink/Linc wrote: What are you using to make those tutorials? The are really nice!
It's freeware and has versions for both Linux and MS-Windows users.
Enjoy!
- gordonmarkus
OK - I think I am getting the hang of this now, but may have found a bit of a bug...
I've made the file association changes, and if I click on a stream using konqueror as my browser, then xmms fires up and everything is good. However, if I do the same using firefox then gxine fires up - even though I have removed gxine from being associated in KDE control centre. Anyone else seen this problem?
Thanks again for all your help everyone!
-Gordon.
-Gordon.
