At the moment, I've been coding for almost 14 hours straight and my wrist is killing me. what kind of keyboards do y'all use? I'm willing to shell out $50+ if there's a durable one out there. I have rather big hands if that matters (big enough to palm a basketball). I've been considering going dvorak (does that really help?), but I hesitate b/c I'm a vi user...
thanks
Keyboard Recommendations?
Stay away from newer IBM keyboards. Mine has some problems with repeating characters (when I don't want them to repeat).
My OEM HP keyboard was very durable and comfortable, althought that's the only component from that system that lasted more than 2 years.
If you can get a Dell Quietkey, they're pretty good. I've got one at work I've been pounding on for a couple years 8 hours a day. It's showing a little wear on the <CTRL> and <ALT> keys, but other than that it's solid and very comfortable.
As far as the aftermarket, I always go to Dan's Data for reviews of that kind of stuff. He's a fan of the older IBM buckling spring boards and their clones. You'll have a hard time getting one for $50, though.
What ever happened to those ergonomical keyboards that you can even raise on a ^ form so your wrist don't have to bend. I think thats the one you might want but then again it doesnt look like people can get used to that easily.
I google for ergonomic keyboards and find the one I was talking about however it seems they have newer (better?) models.
Check http://www.kinesis-ergo.com/max-spec.htmThe award winning Kinesis Maxim adjustable ergonomic computer keyboard is now available in a new USB compatible (PS/2-USB switchable) package for Windows, Mac, Linux, and Sun systems!
