Scanner reccomendations
no1important
Post by no1important » Mon Aug 22, 2005 12:53 pm
Good Morning:
I am going to buy a scanner to scan photo albums. I was wondering if anyone had a suggestion for which scanner would work best with Linux (Kanotix)? I don't need anything too fancy just something that does a descent job and is easy to use and I don't want a small one , I need one that will scan 8x11. I heard HP is linux friendly, is that true?. Thanks for any input in advance. :D
Post by Judland » Tue Aug 23, 2005 9:59 am
You may find something useful here.
Although it's a Mandriva compatibility chart, it still might help you in general.
no1important
Post by no1important » Tue Aug 23, 2005 11:02 am
Thanks :) I will check it out.
