Pointer Guide
fingolfin
Pointer Guide
Post by fingolfin » Wed Jun 16, 2004 4:36 pm
http://thelinuxlink.net/~fingolfin/pointer-guide/
Please review for accuracy, clarity, etc.
I'm so happy
'Cause today I found my friends
They're in my head
pthread
Post by pthread » Wed Jun 16, 2004 8:23 pm
Ha, I just skimmed it... but the "shizzle" made me LMAO.
fingolfin
Pointer Guide
Post by fingolfin » Fri Jun 18, 2004 10:26 am
pthread wrote:Ha, I just skimmed it... but the "shizzle" made me LMAO.
Ok, but, what did you think about the content?
I'm so happy
They're in my head
dstate
content
Post by dstate » Sun Nov 14, 2004 4:02 am
It seems pretty good. Maybe when my vision isn't as blurry in the morning i will look at it again incase i see anything. Though IMO you do not need to do int baz[4] = { 1, 2, 3, 4} }; it can be int baz[] = {1, 2, 3, 4 }; and if you do need the number there it is usually in the case of growing your array in which case if you do things like for loops throughout the code it would be smart to set a define such as MAX etc. otherwise you will be chasing down various portions of code. I do understand its a pointer tutorial, but keeping good practice is something one should always display so others do not get wrong ideas ;)
#include <stdio.h>
#define MAX 4
int main (void)
int baz[MAX] = { 1, 2, 3, 4 };
for (int i = 0; i < MAX; ++i)
printf ("%d\n",baz);
return 0;
:shock: :shock: :shock: :shock: :shock:
"The complexity of software is an essential property not an accidental one."
--Brooks
