Will this be a Watergate for Democrats?
Re: Will this be a Watergate for Democrats?
And what has this got to do with Linux?
Well, seeing as it's under the "Anything Goes" section it's kind of self-explanatory.
I did contemplate which forum to put it under. There are a lot of things discussed on the regular forum that have no linux bearing. Since the issue was computer related, I felt that forum might have more validity. The fact that the forum has changed makes no difference to me as long as the issue can be discussed. I wonder if he allegedly was using linux or some system in between while trying to guess the password was using linux or bsd..
