Automatix - Is it worth it?
ubergeekinc
Post by ubergeekinc » Sat Dec 23, 2006 2:55 pm
I recommend it. Can you do it manually - of course. Could you find a better use of your time - I hope so.
Set it up - install the selections that you want then you never need to use it again. Apt-get will keep your debs up to date, as long as you leave the sources alone.
