Which podcast receiver do you use?
Which is it?
BashPodder, of course!
4
31%
jPodder
0
No votes
CastPodder (formally iPodder)
3
23%
Manual download with wget, Firefox, etc.
1
8%
iTunes (cringe)
1
8%
Podget
0
No votes
Something else?
4
31%
Total votes: 13
treehead
gnupod & amarok
Post by treehead » Thu Mar 09, 2006 8:07 pm
Snarkout wrote:I actually use amarok to do my pod catching, but right now their interface with the iPod is lacking. You can put tunes on the iPod easily enough,but the genres and playlists don't seem to get populated. I'm hoping that 1.4 helps this - I absolutely love amarok at this point!
;so you use amarok for the rss, and gnupod for syncing your ipod?
;i saw this:
GNU wrote:2. Requirements
To use GNUpod, the follwing is needed:
* iPod (HFS+ or FAT32)
* Firewire card that is supported by the Operating System
;do you have to have firewire, or will it work with USB 2?
;treehead
Post by snarkout » Thu Mar 09, 2006 8:42 pm
Yeah, I use amarok to pull my podcasts and gnupod to synch. Gnupod really only allows you to add or remove, not really "sync." I haven't found this to be an issue at all though. One thing I'd really like is the ability to ignore directories when filling my ipod up, though, since I have a lot more music than will fit on my iPod.
IIRC it works fine over usb2, but I don't use usb2 since I haven't figured out a way to get my workstation or lappy to charge my ipod over it.
treehead
wait a week...
Post by treehead » Thu Mar 09, 2006 9:19 pm
CptnObvious999 wrote:.... But you should probly wait a week or 2 since a new successor is supposed to be released at CeBit (I'm sure iAudiophile will have it covered once it gets shown off). Even if you won't buy the new one (assuming there is a new one) the prices could drop even lower. Anyways I am pretty happy with mine.
;i would like to see iaudio put out a 60GB model.
;you mentioned that you're happy with yours... do you have an X5? how's the video playback?
;treehead
Re: wait a week...
Post by CptnObvious999 » Thu Mar 09, 2006 9:30 pm
treehead wrote:;i would like to see iaudio put out a 60GB model.
Well, your in luck, they have! (though it costs a fair amount more than you would like)
treehead wrote:;you mentioned that you're happy with yours... do you have an X5? how's the video playback?
Yes I have an X5 and the video playback isn't that great. Its a pretty small screen and it only supports 15fps but thats not why I bought one. Its just a nice extra, although its not unbearable if you want good video hopefully the successor will be better or you could get a PMP (I suggest the iAudio A2 ;-) ). I use it for Family Guy and some various other Google Video clips, I have watched full movies on it but its not very cinematic :roll:
Post by snarkout » Fri Mar 10, 2006 12:02 pm
Ah. Well, after doing some digging around on the internet and apples site, I discovered that the 3g iPods WILL NOT CHARGE via usb. What a bunch of crap.
Post by Tsuroerusu » Fri Mar 10, 2006 12:04 pm
Snarkout wrote:Ah. Well, after doing some digging around on the internet and apples site, I discovered that the 3g iPods WILL NOT CHARGE via usb. What a bunch of crap.
Well, it's a superior Apple product you know. :wink: :P :D
shopRatt
Post by shopRatt » Fri Mar 10, 2006 8:11 pm
"One of the only things that bugs me about podcasts is that they are almost certainly tagged in ways that makes them hard to keep organized. I have to re-tag nearly every podcast I download."
I could not agree with you more! I can't stand having to rename every podcast becase someone decided to change the naming convention every week. One week a podcast is tagged podcast the next it is blues (when it is not) the next it is rock. TLLTS does a pretty good job though. I just save that to its own playlist and go from there.
Also podcasts that dont have either the date, or the show number as the title. Sometimes I have over 15 of one podcasts, and I have to scroll to find out which ones I have already listened too. IT Conversations is good for this, I wish he would add a date in the title.
//brian
Post by snarkout » Fri Mar 10, 2006 8:42 pm
Unless, god forbid, you ever try to search for it by artist.
Post by CptnObvious999 » Tue Mar 14, 2006 7:36 pm
For a followup to my last post they didn't release any new players as Cebit (which shocked a lot of people at iAudiophile.net). Right now I am not that happy with my iAudio X5 since they will likely not be supporting it anymore (in regard to firmware). I am starting to think I would rather have an A2, although it isn't quite as small as my x5 (image) it has much better video and the wider screen makes it better for text files and photos (pr0n ;-) j/k ) it also has everything my X5L does (although the 30GB is $100 more than the 30GB X5L). I will be sending it back over the weekend and hope it works perfectly when it comes back.
EDIT: the latest (and probly last big) fimware enables you to use the USB-OTG port as a regular USB port for your X5 (although it can't charge it using it) but the A2 doesn't even use a subpack which is another thing I don't have to carry around.
