hellonorman
Post
by hellonorman » Thu Jul 06, 2006 2:38 pm
I am sort of an irc noob. My knowledge is bascially open xchat-->connect to freenode-->type /join #{whaterver channel}.
So Wed I thought I might join the irc during the show. I couldn't figure out how to get there
I understand that the server is thelinuxlink.net and the channel is techshow but I wasn't sure how that fit into xchat. I would add thelinuxlink.net as a server but it never seemed to work.
Is thelinuxlink.net at the same level as freenode?
Can someone explain how to join using xchat?
Thanks for any help.
- Site Admin
Post
by dann » Thu Jul 06, 2006 8:55 pm
Start up xchat and add a new network. Call it thelinuxlink.
With thelinuxlink highlighted select edit. You should see a new window with servers at the top. By default I believe newserver/6667 is listed. Edit that entry and change newserver to thelinuxlink.net:
thelinuxlink.net/6667
The bottom of this window has a entry for channels to join, enter:
#techshow
Press close and then connect and you should be in.
hellonorman
Post
by hellonorman » Thu Jul 06, 2006 10:40 pm
Thank you. It was the part about newserver/6667 that was tripping me up.
