Gnucash is out at http://www.gnucash.org and is a major release using gtk 2.0 -finally...
GnuCASH has compatibility with proprietary apps like Quicken and you can use the QFX files on gnucash. It also has the more secure double entry accounting. This makes management with more control. Also the mailing list is very friendly and supportive.
GnuCASH 2.0 is out
GnuCASH 2.0 is out
Re: GnuCASH 2.0 is out
Awesome! I have been using Gnucash for years to handle my finances. It will be great to see a GTK2 version.Jza wrote:Gnucash is out at http://www.gnucash.org and is a major release using gtk 2.0 -finally...
I guess I'll wait and see if it shows up in Fedora repositories.
