Nokia 770 Perl Script
Hi this question is for dann, can you provide the link that had that Perl script for the Nokia770 Video re-encoder. I currently have a gui program that does that using PyGTK however I am curious of testing this other perl script.
Re: Nokia 770 Perl Script
Dann doesn't have a 770, but Allan and I do. The script is at:Jza wrote:Hi this question is for dann, can you provide the link that had that Perl script for the Nokia770 Video re-encoder. I currently have a gui program that does that using PyGTK however I am curious of testing this other perl script.
http://bleb.org/software/770/770-encode.pl
