App. of the week suggestion
Post by Judland » Sun May 02, 2004 11:11 pm
How about Mondo Rescue? I use it to backup my system and have actually used it once to recover my HD (this was when I was first learning Linux and unknowingly wiped my HD data).
Others might find it useful, too.
Post by dann » Mon May 03, 2004 8:31 am
That's a good one. Ideally I would like to set up a system, use mondo to back it up, and then perform the restore. That for me will be a couple weeks off when all other things are out of the way for a bit. Unless Allan or Linc want to step up with a spare machine?
Post by Linc » Mon May 03, 2004 5:08 pm
dann wrote:That's a good one. Ideally I would like to set up a system, use mondo to back it up, and then perform the restore. That for me will be a couple weeks off when all other things are out of the way for a bit. Unless Allan or Linc want to step up with a spare machine?
I just got you a sparc 10 man?!
