Bad news regarding OpenMoko NEO1973 in the W. hemisphere
Where are you getting this information from? I've searched around and the only thing I can find is apparently a fud blog posting which is refuted here.
Apparently the neo1973 is a "quadband worldwide gsm headset" - that's from the posting. If you look at the neo1973 specs from the openmoko site you will see that it is listed as triband: http://www.openmoko.com/products-neo-ba ... tdkit.html
Yes, the spec says triband and no 850Mhz. This was updated recently with quad and 850 removed.dann wrote:Apparently the neo1973 is a "quadband worldwide gsm headset" - that's from the posting. If you look at the neo1973 specs from the openmoko site you will see that it is listed as triband:
Go to the OpenMoko community mailing list and search for "Community update: The 850 MHz issue":
http://lists.openmoko.org/pipermail/com ... /date.html
with this post starting it all:
http://lists.openmoko.org/pipermail/com ... 11391.html
