Synaptic in Fluxbox?
frostbyte
Post by frostbyte » Sun Oct 09, 2005 11:30 pm
Hello, I'm new to the forums here, but have been listening to the show for awhile now, and have heard that some of you are using ubuntu. I figured you guys might be a bit more familiar with it than me.
I'm currently using fluxbox on it...is it possible to run Synaptic within Fluxbox? When I try, it seems to try to run Gnome..and just sits there and I have to reboot.
Any Ideas?
Post by dann » Sun Oct 09, 2005 11:42 pm
I run it all the time in Fluxbox. I usually do it from a terminal, or that is the only way it will allow me to run it as I have to run sudo synaptic. It doesn't fire up nautilus at all.
macstevejb
Post by macstevejb » Mon Oct 10, 2005 4:48 am
insert this line into your /.fluxbox/menu directory:
[exec] (Synaptic Package Manager) {/usr/sbin/su-to-root -X -c /usr/sbin/synaptic} </usr/share/synaptic/pixmaps/synaptic_32x32.xpm>
always providing of course you have synaptic pre-installed in your distro, otherwise obtain via apt-get.
regards
frostbyte
Post by frostbyte » Mon Oct 10, 2005 12:56 pm
Thanks, that works great.
