Invalid security certificate page notification
Post by LinuxMint-4 » Fri Jun 05, 2009 7:32 pm
( FYI... I got this after I clicked on a topic here...don't know if its important or not)
Secure Connection Failed
www.thelinuxlink.net uses an invalid security certificate.
The certificate is not trusted because it is self signed.
(Error code: sec_error_ca_cert_invalid)
* This could be a problem with the server's configuration, or it could be someone trying to impersonate the server.
* If you have connected to this server successfully in the past, the error may be temporary, and you can try again later.
Re: Invalid security certificate page notification
Post by Patrick » Fri Jun 05, 2009 8:46 pm
You get those when the certificate is not generated by a "trusted" certificate creator. Meaning an agency or company that doesn't want to drop the coin to go through someone like Verisign.
Post by dann » Fri Jun 05, 2009 8:52 pm
That is true. I am not dumping bucks to get an officially signed certificate and yes, I rolled it myself; it's legit.
Post by LinuxMint-4 » Sat Jun 06, 2009 6:44 am
dann wrote:That is true. I am not dumping bucks to get an officially signed certificate and yes, I rolled it myself; it's legit.
Thanks.... I thought maybe some company from Redmond were trying to overtake the server
:mrgreen:
