Hi guys, here are some past presentations about OpenOffice.org 2.0 which might be abel to present the application. Case studies and competitive analisys are also available.
Please read the description for using the proper presentation:
Brochures
Presentation
Right now the hype is toward moving to open standards to assure the longevity of data. Basically if your data is important to you and you need to preserve it for a long time, then you need an open file format like OpenDocuments. Here are some of the most important documents:
http://opendocumentfellowship.org/Main/HomePage
OpenOffice.org presentations
